Apple Numbers Spreadsheet Replacement
I’m looking for a spreadsheet that will match the features of Apple’s Numbers.
So far Libra & Open Office just don’t cut it.
Former Apple users, do you have any recommends?
P.S. I won’t give the evil Google my data… nor any other cloud provider. Any cloud-based solutions are a no go.
Any details concerning what exactly you are missing?
Depends on what kinds of tasks you want to do.
You won’t find an exact match in terms of features, but there’s plenty of software out there for Linux, that can do the same things as Apple Numbers, and much, much more.
For starters:
LibreOffice Calc
https://www.libreoffice.org/discover/calc/
Gnumeric
http://gnumeric.org/
Same Emily problem here! I need a spreadsheet to use it in mode L5 mobile but I can’t find it! I tried both LibreOffice calc and gnumeric but they don’t fit well the screen! Please any suggestion? I don’t need 100% advanced compatibility with MS excel, I just need a basic compatibility to open/create/modify a simple/standard .xls file. I use with success apple numbers, is there something similar for L5?
thank you :sweat_smile::pray:
Already answered in a separate topic:
Thank you for your answer, FranklyFlawless, but as I specified I need to use it in smartphone mode, not desktop one! I can’t carry always Lapdock with me!
Okay, there was a suggestion for Collabora Online in the respective thread:
It was one of the many ideas I had when I originally offered the OVHcloud VPS gratis for the Purism community:
