I’m having trouble applying a dark theme to the Fractal flatpak.
Instead of using the Adwaita-dark gtk theme, I prefer to use adw-gtk3-dark, but I can’t seem to get it to apply to Fractal.
- commands to apply
adw-gtk3-dark:
gsettings set org.gnome.desktop.interface gtk-theme 'adw-gtk3-dark'
gsettings set org.gnome.desktop.interface color scheme 'prefer-dark'
The commands properly apply the theme to the system but not to Fractal, and using Adwaita-dark has the same problem. So I tried applying a flatpak override.
- command to apply flatpak override for
adw-gtk3-dark:
sudo flatpak override org.gnome.Fractal --env=GTK_THEME=adw-gtk3-dark
This removed the border radius from avatar images but did not apply the dark theme itself. However, using Adwaita-dark in the flatpak override command successfully applies the theme to Fractal.
Adwaita-dark:
sudo flatpak override org.gnome.Fractal --env=GTK_THEME=Adwaita-dark
But the avatar images are no longer round, and I don’t like the overall dark theme compared to adw-gtk3-dark.
So can anyone please help me either apply the adw-gtk3-dark theme to Fractal or modify the Adwaita-dark theme to become adw-gtk3-dark?
Thank you.
