Is there a good audio book player?
That can treat a folder as a book?
And have ability to have playback speed and resume position?
This one is pretty good ![]()
You could install it either from Flathub, or from Purism’s flakpaks.
It works great thanks.
I couldn’t find it via the store, so added it like this. hope this is correct.
sudo flatpak remote-add --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo
sudo flatpak install flathub com.github.geigi.cozy
flatpak installs are per user, no sudo necessary. ![]()
initially i did it without sudo, remotely over ssh as the purism user.
It prompted me for password (auth kit, or polkit, or something “kit”). After it prompted like 20+ times, I eventually cancelled it and did it via sudo and then only got like one prompt.
Once Flathub is installed, flatpaks will then appear in the store alongside native packages.
Cozy is great, and a good choice. Other known options can be found here: LinuxPhoneApps
