I’ve two audio questions for the Librem 5:
- Is it possible to set the audio output for a specific application (flatpak app) to default to a specific audio output, without changing the output for other applications? My use case is that Signal Desktop, which I have installed as a flatpak always uses the audio output of the Speaker - Built-in Audio. I prefer to have that by default as Handset - Built-in Audio.
- Is it possible to put the volume to more than 100%? On my Fedora laptop running GNOME I can do that, I forgot if I did something specific to make this possible. My use case is that I’m often listen to podcasts using the Speaker - Built-in Audio, but the volume is often too low in a noisy environment (also because some of the podcasts I listen to have a too low volume compared to some other podcasts). I tried:
as suggested in this issue, but that did not give me the possibility to go over 100% volume (using the GUI) on Crimson.gsettings set org.gnome.desktop.sound allow-volume-above-100-percent true
