Autoswitch audio output when headphones plugged in
Does anyone know if there is a way to have the Librem 14 automatically change the audio output to the headphones when headphones a plugged into the headphone jack?
Also, is there a way to quickly access the Sound settings from the top system tray where the battery settings, wifi indicator, etc. are?
Thank you.
I didn’t get a response from the community so I wrote Pur.ism support and got this answer:
"As far as I understand from our developers, this is a bug in GNOME, so we need to be patient until it is solved. You updated to latest EC firmware, correct? (I have)
As a workaround you can try this plugin: https://extensions.gnome.org/extension/906/sound-output-device-chooser/"
That looks like what I’ve wanted for soooo long. So, how do you install it?
