Is there a way of knowing how ‘healthy’ the librem 13 v3 battery is?
thanks
You can type
upower -d
in a terminal. The output looks something like:
native-path: BAT
vendor: TPS
model: S10
power supply: yes
updated: Thu Aug 22 07:05:01 2019 (40 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: fully-charged
warning-level: none
energy: 44.5258 Wh
energy-empty: 0 Wh
energy-full: 44.8662 Wh
energy-full-design: 44.696 Wh
energy-rate: 6.29 W
voltage: 8.331 V
percentage: 100%
capacity: 100%
“Capacity” is what you are looking for. Also “energy-full” tells you your current max Wh.
OK, that’s helpful
Thank you:+1:
