Hi, I was hoping to upgrade the RAM in a Librem 15 but I’m not terribly familiar with laptop RAM. Can someone tell me the exact requirements that need to be met and perhaps suggest a good 16 GB RAM option? I tried to look into it myself and https://www.newegg.com/Product/Product.aspx?Item=N82E16820232149 seemed like a solid option, but it would be nice if someone could confirm for me so I don’t order something incompatible.
Also I was under the impression the supported speed was only up to 2133 MHz, but when I searched the model number of the default RAM is told me 2400 MHz. Which is the correct max speed?
Edit: No replies, tried to look up info on my own the best I could. Bought the above RAM.
