Bluetooth headphones A2DP issue
I hope this will help.
If you have a problem with not being able to re-connect your bluetooth headphones to A2DP profile.
This is a page with a great solution.
I searched far and wide - this did the trick for me.
It might just do it for you!!
This is the link to the page
A2DPBluetooth Headset
The solution was in a blog that was later deleted.
Someone managed to re trace the steps
Honestly it is a charm
here are the steps [copied from the above link]
Bug and possible solution: actually I found a bug in that make the headset unusable, it seems that the pulse audio module: module-bluetooth-discover works only if started after the X11 session is up. So I have a workaround.
Edit the file:
/etc/pulse/default.pa
and comment out (with an # at the beginning of the line) the following line:
#load-module module-bluetooth-discover
now edit the file:
/usr/bin/start-pulseaudio-x11
and after the lines:
if [ x”$SESSION_MANAGER” != x ] ; then
/usr/bin/pactl load-module module-x11-xsmp “display=$DISPLAY session_manager=$SESSION_MANAGER” > /dev/null
fi
add the following line:
/usr/bin/pactl load-module module-bluetooth-discover
This way the Pulse audio’s Bluetooth modules will not be downloaded at boot time but after x11 is started.
THANK YOU! This issue was driving me nuts!
Glad to hear that.
These things are sent to test us…
