I’m wondering if this is a “just me” issue or if others are seeing the same or similar?
Evergreen - amber-phone - 5.11 kernel:
If I disable Bluetooth from the main settings, subsequently re-enabling via the toggle option does nothing (the window stays displaying the large Bluetooth logo and the message “Bluetooth Turned Off”).
In order to re-enable Bluetooth I have to have the main toggle set to enabled/on in the main settings then from the terminal restart the Bluetooth service ( sudo systemctl restart bluetooth )
I do not see this issue on the 5.9 kernel.
