As a hobby project, I’d like to rebuild my (admittedly rarely-used) Librem 13 with a “from scratch” Linux distro, mostly to improve my understanding of Linux.
Are there any particular pitfalls to watch out for when doing this with the Librem? What’s the best way to get started with such a project? I don’t want to just wipe the thing and get lost, of course.
It is a very very good project.
To tackle that without any fear of crashing it all I would first learn how to completely install a fresh PureOS on my Librem.
You’ll know then that whatever happen during you experimentation you will always be good at reverting to a clean state.
It is always a good skill to have anyway.
PureOS installation is documented on puri.sm.
After that experimenting with LFS will be even more rewarding considering that OS installation from a validated release is level 1 and LFS is level 2 to …
Since it wasn’t mentioned in the text of your post, perhaps you aren’t aware that Linux From Scratch is a real project.
You could always set up a virtual machine to try things in, and if your mess things up in the virtual machine, it’s no big deal, you can just revert to a previous state or wipe it and start over, without any risk to your actual OS.
Yup—LinuxFromScratch was actually the first thing I came across, but I forgot the name, and came across BYOL when I made the original post. Doing my first tries at building a Linux in a VM is definitely a good idea. Thanks!
