I will try to fix this issue https://source.puri.sm/Librem5/OS-issues/-/issues/295 (ignore that the issue starts with a stellarium problem, at the end it is one with telegram-desktop, just scroll down) and compile Telegram from the sources…
The journey starts with cloning from git and install tools:
git clone https://github.com/telegramdesktop/tdesktop.git
sudo apt install curl
get poetry:
curl -sSL https://install.python-poetry.org | python3 -
cd tdesktop/Telegram/build/docker/centos_env
poetry install
poetry run gen_dockerfile | docker buildx build -t tdesktop:centos_env -
-bash: docker: command not found
I tried to install docker with sudo apt install docker, but this isn’t docker. It’s only this
$ apt show docker
Package: docker
Version: 1.5-2
Priority: optional
Section: x11
Maintainer: Paul Tagliamonte <paultag@debian.org>
Installed-Size: 9,216 B
Depends: wmdocker
Download-Size: 2,556 B
APT-Sources: http://repo.pureos.net/pureos byzantium/main arm64 Packages
Description: transitional package
This is a transitional package for system tray docking application.
It can safely be removed.
Thanks for the help. I installed it (and what was pulled in by it), but this docker tool does not fit the build instructions:
unknown shorthand flag: 't' in -t
See 'docker --help'.
Usage: docker [OPTIONS] COMMAND
Run 'docker COMMAND --help' for more information on a command.
To get more help with docker, check out our guides at https://docs.docker.com/go/guides/
File "<string>", line 1, in <module>
File "/usr/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 790, in exec_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "/home/purism/guru/tdesktop/Telegram/build/docker/centos_env/gen_dockerfile.py", line 4, in <module>
from jinja2 import Environment, FileSystemLoader
ModuleNotFoundError: No module named 'jinja2'
So, I give up building it on the L5 itself. I have an older amd64 laptop collecting dust, what would be the best (read closest to L5) to install, perhaps a Debian, but which version? Or PureOS itself?
I’d go for building on an up-to-date (and fast) desktop. On e.g. Debian you have phosh/phoc/squeekboard packages so you can run telegram-desktop nested on your desktop in a minimalistic phosh session which will make developing way simpler than directly on the device.
