Running sudo dpkg --configure -a notes that headers for kernel can not be found from their respective folders. So it’s apparently using old kernel (not even previous in this case) and not the latest - which related version files seem to be flashed to boot/initramfs. Otherwise everything seems to update. Reboot brings out the inability to start LUKS prompt - unsurprisingly, noting the kernel version differences… So, re-doing again.
But the headers exist (link), but another package seems to be missed…
No, everything must be there. Could you provide the exact output of the sudo dpkg --configure -a command?
Not untill I get to re-do the update again
Update shows:
dpkg: error processing archive /temp/apt-dpkg-install-3fS3AR/11-bluez_5.79-1_arm64.dep (--unpack): trying to overwrite '/usr/lib/systemd/user/mpris-proxy.service', which is also in package librem5-base-defaults66pureos1~byz1 and at the end there’s a note that needrestart is being skipped since dpkg had error
And dpkg --configure -a shows:
Setting up linux-image-6.6.0-1-librem5 (6.6.83pureos1~byz1.4) ... dkms: running auto installation service for kernel 6.6.0-1-librem5:Error! echo Your kernel headers for kernel 6.6.0.-1-librem5 cannot be found at /lib/modules/6.6.0-1-librem5/build or /lib/modules/6.6.0-1-librem5/source. You can use the --kernelsourcedir option to tell DKMS where it's located..
I’ve stopped there for now (will be back in an hour or two).
That is exactly what I talked about, try to install librem5-base-defaults first, the version must be 66pureos1~byz3.1.
Regarding to the second issue… In fact I have no installed kernel headers package, will try to check. It may also be related to the first issue as far as upgrade has not completed.
Nah, no change with installing that first. Still missing those headers, preventing those installations.
But the first issue should disappeared at least and apt dist-upgrade should finished without errors.
I just ran sudo apt dist-upgrade when those came up and everything (but the camera) works normally.
On the camera side, none of the the listed commands work for me
try to turn off and on camera kill switch… and let’s continue in another thread ![]()
Still not going the right way. I’ve lost all network connectivity after doing update (while apparently having all the files - including those mentioned at Codeberg). Managed that with the “use old disc image of boot partition” trick to get phone to boot (not fail with LUKS prompt) after update - takes forever to boot now though. No wifi, mobile data nor usb-lan. Curious…
What is your state before upgrade? Clean Byzantium or Byzantium with backports? how old?
I’ve tried a couple of versions but mostly backported backup from end of January, I think. [Currently taking a break and going to Crimson test image to see what has been happening]
Ok. But one more idea to check - just remove linux-headers before upgrade.
Nope. I’m thinking the time between updates has been too long and apt just isn’t able to figure things out. I had similar problems with Crimson testing too, it too didn’t want to boot either on any of the tries and installations after these updates, no matter what I installed before dist-upgrade. Annoying.
I’ve just push the commit where I try to fix this issue by removing conflicting file from bluez package rather than librem-base. In fact there is no difference as the files are the same.
Phosh 0.46 is here! Wow!
For Gnu Crimson? as i not using Biz anymore as too old.
Thank you ![]()
A little bit later… right now I’m trying to upgrade mesa that requires newer rust that requires clang-17 for which I spend the last week because it failed in the last stage several times. ![]()
So, I went back and started from scratch: clean byz flash and so on - trying to chart how currently starting using backports goes.
- After clean byzantium flash an update and reboot - ok
- Then added backports - ok
- Started dist-upgrade - got what @VClaw had first week of January (“Yes do as I Say”), due to librem5-gnome was to be removed (and nautilus as a bonus)… so: “No”
- Then did (just) upgrade - no dangerous requests but got the libtss* related errors (“dpkg: error processing package libtss2-esys-3.0.2-0:arm64 (–configure): dependency problems - leaving unconfigured” AND “dpkg: dependency problems prevent configuration of libtss2-tcti-mssim0:arm64: libtss2-tcti-mssim0:arm64 depends on tpm-udev; however: Package tpm-udev is not configured yet. libtss2-tcti-mssim0:arm64 depends on libtss2-mu0 (>= 3.0.1)” and then a list consisting of tpm-udev and libtss2-* x7) [allowed for automatic service restarts]
- Then did the dist-upgrade - took the chance and commanded (in loud booming voice) “Do as I say!” [L5 did not immediately catch fire], which went through with errors about 49-gnome-console and network-manager being de-configured
- Then followed that with sudo apt --fix-broken install - which reinstalled gnome-console and did a lot of configuring to network stuff… and no errors
AND just to be on the same side, one more update & dist-upgrade - which found a few more to install … but no errors, but some 21 packages were kept back (chatty, eog, evolution-data-server gir1.2-gnomedesktop-3.0 gnome-calendar gnome-control-center gnome-controlcenter-data gnome-desktop3-data gnome-initial-setup gnome-session-bin gnome-settings-daemon gnome-settings-daemon-common gnome-weather libpurple-bin phoc phosh phosh-tour pidgin-data purple-xmpp-carbons purple-xmpp-htt-upload sqeekboard - nothing reeeeeaally important, right) - Tried to install the 21 missing but that doesn’t go through as libdisplay-info1 is not installable, has not installation candidate, but is a requirement for libwlroots-0.18
… and that’s where I’m at the moment with trying to get backports installed. Any chance that libdisply-info1 is something that can be added to backports? Could it be the culprit that prevents a straight up installation or is this just a symptom of too many steps and telling system to do silly things when I should know better? I dare not reboot and keep it powered if by chance this is still fixable - so I wait.
Oh… I’v push libdisplay-info2 and believed that it replaced libdisplay-info1 but it is wrong. The last one still required. I’ve returned it back, please try again. ![]()
