That link is no longer up-to-date. This is the up-to-date
Yeah, about old linksâŚ
The link you provided goes to https://codeberg.org/galilley/librem5-byzantium-backports where there is another link:
âfor detailed description.â
and that link (https://forums.puri.sm/t/byzantium-backports-unofficial/"(for detailed description.)
results in:
Oops! That page doesnât exist or is private.
A long bumpy ride back to square one.
~s
Unfortunately I can not edit the first message int this thread anymore, so, please follow the next one, marked as a solution.
About the files to download⌠I believe that the rules are the same for all domains independent of political agenda - you must be careful, check extensions, use antivirus software and so on
. If I were you and worried that someone will track my downloads, I would use tor. And the last point - I did not recommend to use Yandex Browser and can not recognize how it related to the file upload serviceâŚ
p.s. sorry for the bad links, fixed.
Thank you for the redirect. Looks too complicated with all the try this and such. Iâll wait.
~s
Yes, you are right, the whole installation is quite complicated and could result in some non-trivial problems⌠But if you are interested in some special programs I could try to rebuild that in a clean Byzantium environment like phosh-antispam.
But if you are interested in some special programs I could try to rebuild that in a clean Byzantium environment like phosh-antispam .
Sorry itâs taken a while to reply.
Can you PM me costs in CAD$?
~s
It is for free!
But if you like to support me you might send some CAD$ for a coffee to my crypto wallet or visa card ![]()
Hi @galilley is the installation still the same? We do full upgrade twice then install kbd those missing apps? I am planning to try again. ha, thanks.
Hi! Welcome back! ![]()
Yes, the installation must be the same. kbd should be installed automatically as I changed dependency in phosh to mandotary.
Thanks, will try on my other none daily driver one, by the way, I received two updates on byzantium in these two weeks. I am surprised that they still the update these days while slowly working on the crimson. I hope Crimson doesnt get delayed until next year based on their one blog per month ha. anyone receive the updates from the byzamtium as I do?
And the third one is coming soon - modemmanager 1.24 (1.23.95 in fact). The most interesting feature according to news page is: support for putting modems in low-power mode during suspend.
Iâm also working slowly with Crimson backports to align the versions of the most required packages to Byzantiumâs one. After that I will try to migrate. Hope it will be in this year ![]()
so they are updating the byzantium while developing the Crimson as well? that is nice.
I meant backports for both distro, Cri and Byz. ![]()
Oh, that is not what the updates that I mentioned above. I havenât installed urs yet but I received two updates from the purism byzantium repo, one of the package is librem5-base-default I believe. I am on a clean byzantium.
@galilley Phosh 0.46.0 is out!
Is it coming to backports?
Definitely YES!
I will start right now, just give me a few days ![]()
new pipewire, rebuilded libcamera and reconfigured kernel to use Cameras everywhere!
I got a âErrors were encountered while processing: /temp/apt-dpkg-install-jAY360/04-bluez_5.79-1_arm64.dep needrestart is being skipped since dpkg has failedâ. And apparently after reboot the touchscreen doesnât work (which is a bummer when you need to enter LUKS).
OoopsâŚ
bluez_5.79 conflicts with librem5-base-defaults but it should be resolved by apt (I propose the version 66pureos1~byz3.1) . So, you could try to upgrade it first.
Touchscreen⌠it may be related to i2c bus recovery enabled in dts file (which also included in this kernel) by the patch. But I have no issue with my touchscreen⌠Everything works fine.
Iâll have another go after Iâve re-written the eMMC with a disc image backup (once again).
