Can't Power Off - app running?
New shut down must have come through on updates.
Slide down to get to Notifications screen.
Click the power button top right.
New Options:
Power Off
Lock
Screenshot
Emergency
Click Power Off: displays error:
“Click Some applications are busy or have unsaved work”
option is Cancel or Power Off
I won’t Power off because I don’t know what will get chomped if I do.
Ideas?
Just do it. It shows this message everytime for me. Afaik showing which application is causing that is in the works ( I saw a screenshot on https://phosh.mobi/releases/rel-0.27.0/#phoc-0270 )
Yes you can shut it down. If you do not remember the app/program which loose unsaved Information. Its like on the Desktop Computer where you open the Editore take some unimportant Note. Click not “Save As…” and the generated run time information will be lost.
On the Phone i think you may have that app open and not Closed. On new Android Phones you have to swipe left and right after clicking the center Button, and Closing Apps by swiping them upward or click the X on the top right button.
Its just for the cases like, that you Open an Editor and do not save the changes of some file while the editor Session is still running. And if you then will shutdown it is a warning for you.
For the record, the latest version of phosh has a bug that makes it show this message even though no application is actually busy. It will be fixed with the next phosh update.
