Not sure if this was brought up before, but one minor annoyance that I hope can be addressed is being able to change the audio path from BT to handset right from the call screen, I find myself just turning off bluetooth to disconnect the audio path then there is that awkward stage while it does that and I go to the handset audio. Also it appears the echo cancellation isn’t working well with BT devices (my wife complains about echo when I try to use a BT device in a call and hence the motivation behind this post…lol).
