Hi,
Pureboot latest version 20:
I did a factory reset and used a new smart card (LK: 3.3v).
At the end of the process everything works fine.
However, now I like to use my old smart card with my old keys (NK: 3.3v) again.
I follow the instructions as at: https://docs.puri.sm/PureBoot/GettingStarted.html: Changing GPG Keys.
The first step “Options → GPG Options → Replace GPG key(s) in the current ROM + reflash” seems to work fine.
However, the second step “Options → Update checksums and sign all files in /boot” always ends with: “Failed to update checksum / sign default config”.
A reboot results with the following:
*** Found vereified kexec boot params
gpg: verify signatures failed: Unknown system error
Invalid signature on kexec boot params
!!! Failed default boot
New value pf PCR[] 4: …
!!! Starting recovery shell
When going to **Options → Boot Option → Show OS boot menu", no selection is show and the main menu is displayed.
Kind regards,
