@Jt0, in order to get relevant output (that you can compare/post here) you would need to execute above three commands at first place, those commands provided here from @dos, and afterwards connect (connect/disconnect) related power supply/supplies. Ctrl+C to exit.
Here’s the output from connecting the charger for a few seconds:
irq/34-0-003f-217 [003] ..... 55553.068471: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55553.069113: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55553.069712: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55553.164906: tps6598x_irq: event1=ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55553.165754: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55553.170460: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55553.171164: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55553.202729: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55553.203434: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55553.204020: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55553.205266: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55553.211461: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55553.212182: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55553.213017: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55553.213108: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55553.217024: tps6598x_irq: event1=ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55553.217724: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55553.286145: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55553.286857: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55553.342644: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55553.343358: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55553.344032: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55553.344121: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55554.167115: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55554.182115: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55554.191269: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55554.243987: tps6598x_irq: event1=ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55554.244785: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: fault, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55554.249012: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55554.249706: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: fault, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55554.281637: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55554.282336: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55554.282990: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55554.284199: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55554.288506: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55554.289184: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55554.289897: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55554.289988: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55554.293928: tps6598x_irq: event1=ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55554.294637: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55554.367400: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55554.368090: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55554.421227: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55554.421912: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55554.422616: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55554.422673: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55555.233782: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55555.234478: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55555.235082: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55555.322272: tps6598x_irq: event1=ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55555.323149: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: fault, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55555.327789: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55555.328505: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: fault, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55555.361401: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55555.362110: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55555.362765: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55555.363981: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55555.368294: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55555.369021: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55555.369764: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55555.369884: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55555.373886: tps6598x_irq: event1=ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55555.374588: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55555.445660: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55555.446362: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55555.500948: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55555.501962: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55555.502544: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55555.502649: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55556.324873: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55556.332496: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55556.334405: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55556.406078: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE|ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55556.406760: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55556.445338: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55556.446016: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55556.446602: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55556.447391: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55556.454335: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55556.455058: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55556.455754: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55556.455830: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55556.459237: tps6598x_irq: event1=ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55556.459938: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55556.528785: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55556.529488: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55556.582138: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55556.582837: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55556.583523: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55556.583626: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55557.411511: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55557.424564: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55557.432320: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55557.484770: tps6598x_irq: event1=ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55557.485469: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: fault, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55557.490054: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55557.490746: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: fault, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55557.522762: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55557.523412: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55557.524021: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55557.525183: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55557.529426: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55557.530126: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55557.530824: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55557.530925: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55557.534933: tps6598x_irq: event1=ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55557.535562: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55557.607067: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55557.607769: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55557.664650: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55557.665357: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55557.666058: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55557.666131: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55558.485139: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55558.494380: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55558.502772: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55558.564904: tps6598x_irq: event1=ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55558.565615: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55558.570071: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55558.570765: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55558.602903: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55558.603553: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55558.604209: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55558.605451: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55558.609752: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55558.610487: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55558.611212: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55558.611292: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55558.615342: tps6598x_irq: event1=ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55558.616035: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55558.689384: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55558.690341: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55558.748739: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55558.749437: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55558.750129: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55558.750192: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55559.554092: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55559.555085: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55559.555661: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55559.646413: tps6598x_irq: event1=ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55559.647184: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55559.651420: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55559.652121: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55559.687147: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55559.687840: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55559.688409: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55559.689202: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55559.693899: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55559.694597: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55559.695301: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55559.695377: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55559.698991: tps6598x_irq: event1=ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55559.699682: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55559.770605: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55559.771306: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55559.823694: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55559.824385: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55559.825083: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55559.825167: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55560.649435: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55560.658492: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55560.668747: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55560.726747: tps6598x_irq: event1=ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55560.727548: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: fault, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55560.731878: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55560.732586: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: fault, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55560.765110: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55560.765813: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55560.768256: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55560.769031: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55560.773359: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55560.774171: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55560.774900: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55560.774965: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55560.778828: tps6598x_irq: event1=ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55560.779526: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55560.853561: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55560.854262: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55560.904251: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55560.904934: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55560.905605: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55560.905667: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55561.711650: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55561.712347: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55561.712933: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55561.810077: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE|ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55561.810782: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: fault, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55561.846363: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55561.847149: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55561.848167: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55561.848974: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55561.853256: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55561.853970: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55561.854982: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55561.855064: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55561.858953: tps6598x_irq: event1=ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55561.859644: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55561.931742: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55561.932421: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55561.984855: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55561.985556: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55561.986242: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55561.986307: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55562.803047: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55562.815283: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55562.823214: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55562.900852: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE|ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55562.908207: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: fault, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55562.926259: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55562.926965: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55562.927578: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55562.929225: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55562.933451: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55562.934159: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55562.934859: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55562.934910: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55562.938946: tps6598x_irq: event1=ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55562.939646: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55563.010490: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55563.011189: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55563.065555: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55563.066251: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55563.066957: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55563.067061: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55563.889744: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55563.900970: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55563.907346: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55563.969349: tps6598x_irq: event1=ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55563.970134: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55563.974444: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55563.975140: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55564.007411: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55564.008112: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55564.008721: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55564.009901: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55564.014038: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55564.014770: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55564.015472: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55564.015569: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55564.019682: tps6598x_irq: event1=ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55564.020396: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55564.093212: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55564.093907: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55564.153351: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55564.154047: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55564.154739: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55564.154806: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55564.794687: tps6598x_irq: event1=PLUG_EVENT|USB_HOST_PRESENT_NO_LONGER|PP_SWITCH_CHANGED|POWER_STATUS_UPDATE|DATA_STATUS_UPDATE|STATUS_UPDATE|USER_VID_ALT_MODE_EXIT, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55564.803840: tps6598x_status: conn: no-conn, pp_5v0: off, pp_hv: off, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe0V, usb-host: no, legacy: no, flags:
irq/34-0-003f-217 [003] ..... 55564.807411: tps6598x_power_status: conn: 0, pwr-role: source, typec: usb, bc: sdp
irq/34-0-003f-217 [003] ..... 55564.808085: tps6598x_data_status:
irq/34-0-003f-217 [003] ..... 55564.808216: tps6598x_data_status:
irq/34-0-003f-217 [003] ..... 55582.959935: tps6598x_irq: event1=PLUG_EVENT|PP_SWITCH_CHANGED|POWER_STATUS_UPDATE|DATA_STATUS_UPDATE|PD_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55582.960635: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: no, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55582.961256: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55582.964210: tps6598x_data_status: DATA_CONNECTION|USB2_CONNECTION|USB3_CONNECTION
irq/34-0-003f-217 [003] ..... 55582.964368: tps6598x_data_status: DATA_CONNECTION|USB2_CONNECTION|USB3_CONNECTION
irq/34-0-003f-217 [003] ..... 55583.054915: tps6598x_irq: event1=ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55583.055818: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55583.060458: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|USB_HOST_PRESENT_NO_LONGER|DATA_STATUS_UPDATE|STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55583.061172: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55583.062255: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55583.062391: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55583.093467: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55583.094255: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55583.094962: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55583.096129: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55583.100912: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|PD_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55583.101663: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55583.105660: tps6598x_irq: event1=ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55583.106407: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55583.176646: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|PD_STATUS_UPDATE|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55583.177262: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55583.229096: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55583.229798: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55583.230498: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55583.230656: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55584.036039: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55584.036765: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55584.037381: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55584.129581: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE|ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55584.130401: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55584.168009: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55584.169031: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55584.169673: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55584.170895: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55584.175172: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55584.175877: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55584.176580: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55584.176664: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55584.180909: tps6598x_irq: event1=ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55584.181616: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55584.253027: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55584.253729: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55584.308232: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55584.308933: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55584.309638: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55584.309732: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55585.127124: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55585.128204: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55585.130395: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55585.210250: tps6598x_irq: event1=ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55585.210966: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55585.215355: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55585.216043: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55585.247956: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55585.248694: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55585.249304: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55585.250769: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55585.255154: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55585.255881: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55585.256919: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55585.257003: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55585.260746: tps6598x_irq: event1=ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55585.261446: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55585.331245: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55585.331986: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55585.386247: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55585.386947: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55585.387606: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55585.387689: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55586.201835: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55586.204888: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55586.205496: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55586.287100: tps6598x_irq: event1=ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55586.288171: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55586.292599: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55586.293296: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: vSafe5V, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55586.330180: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55586.331198: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55586.331798: tps6598x_power_status: conn: 1, pwr-role: sink, typec: pd, bc: sdp
irq/34-0-003f-217 [003] ..... 55586.332602: tps6598x_pdo: fixed supply, max 3000000uA, 5000000uV, details: ext-power|dr-data
irq/34-0-003f-217 [003] ..... 55586.338034: tps6598x_irq: event1=PD_SOFT_RESET|DR_SWAP_COMPLETE|DATA_STATUS_UPDATE|ERROR_PROTOCOL_ERROR, event2=
irq/34-0-003f-217 [003] ..... 55586.338745: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55586.339463: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55586.339560: tps6598x_data_status: DATA_CONNECTION
irq/34-0-003f-217 [003] ..... 55586.409495: tps6598x_irq: event1=HARD_RESET|BIST|HIGH_VOLTAGE_WARNING|USER_VID_ALT_MODE_EXIT, event2=
irq/34-0-003f-217 [003] ..... 55586.410209: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55586.465779: tps6598x_irq: event1=HIGH_VOLTAGE_WARNING|DATA_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55586.466478: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55586.467178: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55586.467265: tps6598x_data_status: DATA_CONNECTION|USB_DATA_ROLE
irq/34-0-003f-217 [003] ..... 55587.284157: tps6598x_irq: event1=POWER_STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55587.284859: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: pd, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT|DATAROLE
irq/34-0-003f-217 [003] ..... 55587.285461: tps6598x_power_status: conn: 1, pwr-role: sink, typec: 3.0A, bc: sdp
irq/34-0-003f-217 [003] ..... 55587.366769: tps6598x_irq: event1=ERROR_DEVICE_INCOMPATIBLE, event2=STATUS_UPDATE
irq/34-0-003f-217 [003] ..... 55587.367613: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: fault, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55587.371989: tps6598x_irq: event1=SOURCE_CAP_MESSAGE_READY|STATUS_UPDATE, event2=
irq/34-0-003f-217 [003] ..... 55587.372712: tps6598x_status: conn: conn-no-Ra, pp_5v0: off, pp_hv: in, pp_ext: off, pp_cable: off, pwr-src: vin-3p3, vbus: fault, usb-host: pd-no-usb, legacy: no, flags: PLUG_PRESENT
irq/34-0-003f-217 [003] ..... 55587.405565: tps6598x_irq: event1=NEW_CONTRACT_AS_CONSUMER|POWER_STATUS_UPDATE|STATUS_UPDATE, event2=STATUS_UPDATE
