I’m trying to down load Charles Schwab street smart edge and the streetsmartedge.exe file will not open launch or run properly. Is there an add on I need? Thank you in advance
if its a .exe
file then you can only get it to run a computer running windows OS.
Check with the site you downloaded your file from to see if they have a linux version of the program. Ideally a debian .deb
or binary .bin
installer.
PS: you could also install a windows emulator on your linux machine to run windows software.
Remember, WINE (Wine Is Not an Emulator) hahaha
@nse420 That software is not able to run in GNU/Linux system just Windows/Mac they got a cloud option but requires a plugin that only work in Windows/Mac anyway.
It’s also proprietary software.
You can install it trough WINE but i didn’t see any reference of the software working properly.
https://appdb.winehq.org/objectManager.php?sClass=version&iId=30108
I have had very limited success with WINE, too much tweaking required and installation of additional window libraries to get it to work.
I saw CrossOver run on a Linux box once and it was impressive.
