Got version 0.6.0 today. Chats crashes less than a second after starting up. I’ve tried rebooting twice. If I run chatty
from the terminal, it shows a segmentation fault. I can’t use the clipboard from the terminal, so here’s a screenshot.
Here is an issue that sounds similar, with a suggested solution:
Quoting from there:
if you
- stop mmsd-tng
- move
~/.mms
to eg~/.mms.offending
- restart mmsd-tng
mmsd-tng should recreate
~/.mms
and you should have a working chatty. I think chatty even keeps > your APN configuration and SMS stack. But the MMS that broke it should still be in~/.mms.offending
Does that help?
That helps. I had to reboot, because I couldn’t figure out how to restart mmsd-tng
, but yes, I can now start Chats without it crashing.
Hi, the crash has been fixed with https://source.puri.sm/Librem5/chatty/-/merge_requests/1058 and I have made a new 0.6.1 release with the fix included. Let me know if you have any issues with the new chatty.
cheers,
Mohammed Sadiq
