What is the exact CMOS battery connector type and location on a Librem14v1 motherboard with the proper polarity direction? If anyone has an Amazon link for one with a long enough wire that would rock.
My battery has started failing and I use Pureboot, which means the crash and having to keep resetting the clock every time I unplug the laptop to take it anywhere is exasperating.
Here is a photo of my Librem 14 after disassembly:
This one worked with the right polarity and was listed for “Dell XPS 12 9Q23 / Dell XPS 15 L521X / Dell XPS 15Z L511Z”. For some reason the polarity is not standard.
https://www.amazon.com/Battery-Latitude-E6230-E6320-E6330/dp/B08FJ7ZT73
It was the longest I could find but is just barely long enough to be routed next to the 4 cell battery, and came with a foam tape circle to stick it down so it won’t rattle around in there.
