Command-not-found not working
Hi there,
which I mistype a command, command-not-found tells me that I should run update-command-not- found as root. That command completes without output but does not change the situation.
Any fix?
Thanks
Jens
I am not sure if you are seeing a related problem, but this package has had issues recently. I suggest looking at the tracker here.
If yours is the same version, it may help to add information to the bug report.
Thanks! Indeed, that seems to be the same issue, only that I just started using the machine, so I don’t have a history in which this worked at all. I don’t see additional information to provide.
