Here is a spec comparison of the present and upcoming Linux phones in 2026, that I started to compile. I will add links and fill in the blank data later when I have more time, but I thought I would post it now for people who are trying to decide what Linux phone to buy/crowdfund, or just want to compare with previous Linux phones.
| Category | Purism Librem 5 v2 | Dawndrums Divine D. | MNT Vector | Jolla Phone (2026) | FuriLabs FLX1S+ |
| Phone announced | 2026-11-17 | 2025-05-12 | 2025-12-27 | 2025-12-05 | [1]FLX1S+: 2026-05-11 |
| Shipping starts | Apr-May 2028 | not yet crowdfunding | not yet crowdfunding | 2026-07-08 | [2]FLX1S+: 2026-05-31 |
| Price | $1599 (crowd-funding) | ? | ? | €699 (first €499, then €579) | $499 |
| System on Chip | SpacemiT K1 (datasheet) | Rockchip RK3588S (datasheet) | Qualcomm QCS6490 or QCS8550, on 200 pin SO-DIMM card; also testing RK3588 | MediaTek Dimensity 7100 5G | MediaTek Dimensity 900 |
| SoC announced | 2024-04-30 | 2022-01-12 | [3]QCS8550: 2023-04-17 | 2026-01-02 | 2021-05-13 |
| Process node | 22nm planar | Samsung 8nm 8LPP (Low Power Plus) | [4]QCS8550: 4nm | TSMC 6nm | TSMC 6nm |
| CPU | 8x 1.6GHz X60 | 4x 2.4GHz Cortex-A76, 4x 1.8GHz Cortex-A55 | [5]QCS8550: 1x 3.2GHz Cortex-X3, 2x 2.8GHz Cortex-A715, 2x 2.8GHz Cortex-A710, 3x 2.0GHz Cortex-A510 | 4x 2.4GHz Cortex-A78, 4x 2.0GHz Cortex-A55 | 2x 2.4GHz Cortex-A78, 6x 2.0GHz Cortex-A55 |
| ISA | RISC-V RVA22, 256-bit RVV1.0 | ARMv8.2-A | [6]QCS8550: ARMv9.0-A | ARMv8.2-A | ARMv8.2-A |
| Geekbench 6 CPU single / multi-core | 134 / 583 | 730 / 2250 | [7]QCS8550: 1100 / 3300 |
995 / 2900 | 1003 / 2423 |
| GPU | Imagination IMG BXE-2-32 | ARM Mali-G610 MP4 | [8]QCS8550: Adreno 740, ≤680 MHz |
ARM Mali-G610 MC2 | ARM Mali-G68 MP4 |
| Graphics APIs | OpenGL ES 3.2, Vulkan1.3, OpenCL 3.0 Note: Requires proprietary firmware and userspace blob |
[9]QCS8550: OpenGL 4.6, OpenGL ES 3.2, Vulkan 1.4 (Freedreno, Turnip) |
| NPU / DSP | 2.0 TOPS | [10]QCS8550: Hexagon, HVX, HMX, 48 TOPS |
| VPU decode | 4K@60 (H.265, H.264, VP8 VP9, MPEG4, MPEG2, H.263, VC-1) | QCS6490: 1080p@60, 4K@30 (H.264, H265); | |||
| VPU encode | 4K@30 (H.265, H.264, VP8, VP90) | [11]QCS8550: 8K@30, 4K@120 | |||
| Wireless | Wi-Fi, Bluetooth | [12]QCS8550: Wi-Fi 7 (802.11be, 4K QAM, 5.8 Gbps), Bluetooth 5.3 (dual, LE) |
Wi-Fi 6.0, Bluetooth 5.4, NFC | Wi-Fi 6.0 (802.11ax), Bluetooth 5.2 (A2DP, LE) | |
| GNSS | Yes | GPS, Galileo, GLONASS, BEIDOU | |||
| Video out | HDMI 1.4, 4K (3840×2160@30, 4096×2160@24) Note: need extra converter chip for HDMI to DP Alt Mode |
QCS8550: DisplayPort 1.4 (2x 4K60), DP Alt Mode over USB-C | |||
| SoC package | 676-pin FCCSP (17×17 mm) or FCBGA (19×19 mm), 0.65 mm pin pitch; die: 6.54×8.03 mm, 52.52 mm² | [13]QCS8550: 1581-pin MPSP, 15.6×14.0×0.56 mm + PoP RAM |
| SoC support dates | [14]QCS8550: 2023-04 to 2033-04 | ||||
| RAM | 8GB LPDDR4 / LPDDR4X (2666 MT/s)[15] | ≤ 32GB LPDDR4 / LPDDR4X (4224 MT/s) / LPDDR5 (5500 MT/s)[16] | [17]QCS8550: ≤ 16GB LPDDR5 (6400 MT/s) / LPDDR5X (8400 MT/s) |
8GB or 12GB LPDDR4X (4266 MT/s)[18] | 8GB LPDDR4X (4266 MT/s)[19] |
| Storage | 128GB eMMC 5.1, HS400; microSDXC, 80 MB/s, SDR104 | eMMC 5.1, HS400 | UFS 2.1/2.2/3.1 | 256GB UFS 2.2; ≤ 2TB microSDXC[20] | 128GB UFS; ≤1TB microSDXC |
| Display | 5.7" 1440x720, 60Hz, no hardened glass | ? | 7" 1920x1200 | 6.36" FullHD AMOLED, ~390 ppi, 20:9 aspect ratio, Gorilla Glass | 6.7" 1600x720 HD+, 90Hz, Asahi Dragontrail Glass |
| Back camera | 13MP | ? | ? | Sony 50MP wide + 13MP ultrawide | 48MP (f/1.8); 2MP macro (f/2.4) |
| Front (selfie) camera | 8MP | ? | ? | Sony 32MP | 13MP (f/2.0) |
| Ports | USB-C Note: SoC supports USB 3.0 (5.0 Gbps). |
USB-C, HDMI | 2x USB-C | USB 2.0 (480 Mbps), Type-C | USB 2.0 (480 Mbps), Type-C |
| Battery | 4500 mAh | ? | Soldered.com 8000 mAh 3.7V (2x 4000 mAh) | 5450 mAh, user replaceable | 5000 mAh |
| Dimensions & weight | 74×152×15 mm (2.9×6.0×0.6 in) Note: the Librem 5 v1 weighs 262 g (9 oz). |
? | ? | 157×74×9.7 mm, 208 g | 170×76×8 mm, 201 g |
FLX1: 2024-02-01 ↩︎
FLX1: 2024-07-05 ↩︎
QCS6490: 2021-06-07 ↩︎
QCS6490: 6nm ↩︎
QCS6490: 1x 2.7GHz Cortex-A78, 3x 2.4GHz Cortex-A78, 4x 1.95GHz Cortex-A55 ↩︎
QCS6490: ARMv8.2-A ↩︎
QCS6490:
950 / 2850 ↩︎QCS6490:
Adreno 643L, ≤812 MHz ↩︎QCS6490:
OpenGL ES 3.2, Vulkan 1.1, OpenCL 2.0 FP, DirectX 12 ↩︎QCS6490:
Hexagon V66, HVX, 1980 MPPS, 12 TOPS ↩︎QCS6490: 1080p@60, 4K@30 (H.264, H265) ↩︎
QCS6490:
Wi-Fi 6E (802.11ax), Bluetooth 5.2 ↩︎QCS6490: 1287 pin PSP, 14×12×0.91 mm, 0.35 mm pitch ↩︎
SoC supports ≤ 16GB LPDDR4/LPDDR4X or ≤4GB LPDDR3. ↩︎
The LPDDR5 RAM can operate reliably up to 3200 MHz (6400 MT/s), but is optimized for 2736 MHz (5500 MT/s). ↩︎
QCS6490:
≤ 16GB LPDDR4X (4266 MT/s) / LPDDR5 (6400 MT/s) ↩︎SoC supports ≤ 16GB LPDDR5 (5500 MT/s) ↩︎
SoC supports ≤16GB LPDDR5 (5500 MT/s) ↩︎
SoC supports UFS 3.1. ↩︎
