Hi!
I have a keyboard that unfortunately can only be connected through Bluetooth.
I have tested the keyboard with Raspberry Pi 4 with Raspberry OS and it works fine.
When I try with Librem 5 I have the following behaviour:
- Pairing using the Gnome GUI works apparently fine. I get asked to enter a pin through the keyboard and after entering the pin, the keyboard gets saved as a known device so I guess that the Keyboard pairs successfully.
- The keyboard stays after the pairing in “disconnected” state and the connect button in the GUI is gray and inactive.
What could I try to get the keyboard to work?
If it works with Raspberry OS on RPi 4, I guess that there will be a way to bring it to life on Librem 5 as well.
Best regards
Hristo
