I updated to Crimson late, later than I should’ve in the modern era of software vulnerabilities.
Does Lapdock from Purism Store just not work with Crimson? It seems broken and I remember it working fine not long ago.
Works for me, I used it a couple weeks ago to build something small and fun while I was stuck in a car for a couple hours.
Are you using the correct port on the lapdock? They require a specific USB-C port to output the DisplayPort signal.
Is the USB-C cable you are using the original cable that came with it? Is it still working when you test with other devices?
When you have the lapdock plugged in, enter the lsusb command in a terminal. Do you see these entries (NexDock 2025 model):
Bus 003 Device 004: ID 222a:0001 ILI Technology Corp. Multi-Touch Screen
Bus 003 Device 005: ID 258a:0f08 SINO WEALTH NexDock Touchpad Keyboard
Bus 003 Device 003: ID 1a40:0001 Terminux Technology Inc. USB 2.0 Hub
Bus 003 Device 002: ID 1a40:0001 Terminux Technology Inc. USB 2.0 Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
What does convergence mean anymore?
Back in the libhybris days it meant, at least to Ubuntu Touch, that you could launch regular desktop stuff on an android kernel bin blobbed out driver device, so you could use the phone to do desktop tasks with desktop programs ie gtk and qt stuff.
Now I can pretty much run anything I want on a Librem or pine64 but the CPU is slow, so I still want a desktop/laptop for real heavy work. A lapdock is a nice idea but if I am paying for a KB and screen I might as well include a CPU rather than locking my phone into the pseudo-laptop’s KB somewhere or a USB/HDMI/Ethernet hub for a desktop setup. I like my phone in my pocket and I regularly just VNC or SSH in to do stuff on the phone from my computer. I even answer calls on speaker from my laptop.
Someday when the tech race is over and processing is stabilized, and we are not that far, just need to get full libre dirvers for the ‘good’ mobile CPU/GPU hardware and for non-power-users maybe already there.
Everything I have is all Linux/Unix similar software, so in my case everything from servers out in datacenters, to my home computers, my media projector, tablets, router, and phones all work great together and most code is pretty portable.
I know convergence is supposed to be in this context, and I have tried it, but maybe take the everything is talking to everything else smartly and securely pill anons, let all of your gadgets converge.
I am really not trying to diss the lapdock idea, maybe someone could tell me a really cool use case for lapdock/convergence that VNC doesn’t cover. Or maybe the concept of convergence is something completely different in this context.
I’ve been using a mini PC that was more powerful than the Librem 14, often but not always with the lapdock attached as a sort of pretend laptop, but it got me into a habit of traveling with both all of that mess and the Librem 14 and it feels a bit like too much. So I figured I could try to skip the Librem 14 and have only one laptop shell, which is usable with both the mini PC and the Librem 5.
It’s sort of experimental but I wanted to try it. I hope you’re right that eventually things become “stabilized” but I’m moreso convinced that even if they did, we would be pushed into denying or ignoring it by the strong level of manipulation corporations have over people these days.
I get this, I have been going the VNC route to do something similar with a regular ‘gaming’ laptop as I use CUDA for some stuff.
I suppose I could set up a secondary VNC that would match the laptop size vs mirroring my phone screen area UI. Perhaps when I have some free time.
So it turns out the problem isn’t Librem 5/Crimson. I have another machine that historically worked with the Lapdock, and a different USB-C cable (the one that came with the dock) and it isn’t working.
So I either damaged the dock or else it needs to refresh itself somehow. Anybody know if there’s a secret key combo to totally kill the docks inner working and clear them and refresh? I’ve power cycled it with its button but it seems like I could do more.
Edit:
I feel this might’ve happened once before where I fixed it by connecting directly to HDMI, before then going back to USB-C. But I didn’t bring my HDMI cable.
Edit:
Plugging a device into the dock twice on both USBC ports mysteriously unbricked the dock!
