Before seeing the Hoyoki in Purism shop, I ordered a Hoyoki from Amazon (was cheaper as well) and returned it because of a defect in one port. The replacement Hoyoki works fine for me.
I use it a lot and I use a HP Z400 workstation, w/ Blackweb keyboard/mouse combo to a Samsung SyncMaster S27B370 w/ HDMI connection.
The only issue is that L5 Convergence says there are no known docks attached, so a manual trip through Settings > Displays is necessary.
In the image you provide, is the same Hoyoki I have. I think Puri may have changed the hardware out from Hoyoki to SutechSmart is because it appears that Hoyoki no longer sells them.
So whatās the solution to my problem: Iāve got the hub thatās on the Purism site plugged into the L5 (bought from Purism). My wireless keyboard works, the wireless mouse works. I can listen to a movie stored on the L5 with VLC on my Samsung 4K TV. However, I canāt open a browser to surf the Net, and mouse operations are often jerky (lag). When I unplug the Hub, sometimes bugs remain (the L5 tells me that browsers are open and need to be closed, etc.) and the L5 freezes completely. Other times, I can start using the L5 again without any problem once Iāve unplugged the hub (I can surf the Internet, etc.).
Anybody else notice convergence is very flaky again? Maybe it is my hardware. I donāt know. My hubs all hate me and my phone right now. They have all decided to have various annoying flaky issues. I donāt know, sometimes this device ⦠It can be exhausting.
I just spent the morning messing with L5 and didnāt get very far. I started out with just a hub (same brand very similar to the one pictured above, had too many frustrations, so I started using the NexDock accessory I got with the L5 order. The USB hub (this UtechSmart brand) wasnāt givng me wired network connectivity, so I just went straight to the NexDock instead.
After a bunch of messing around with settings and setting display to the dock only (combine/mirror was nothing but problems, hard to describe), I finally got it working pretty well, even with a mouse attached to the dock.
But my data connectivity when on wireless is SO bad I failed installing Librewolf entirely. (Which is surprising because I live in an area which should have good connectivity.) Very slow and then it failed. I think it wouldāve been fine if I could get a wired connection to work.
The phone also got very hot (even after I had the L5 screen turned off), about 50C all around, but thatās another topic. It can be exhausting sometimes.
Once you get things working and youāre using it like that consistently, itās decent. But start changing things up radically and you need to be prepared to try lots of things. I was digging up so many different kinds of various adapters and wires to try different setups that I remembered things I didnāt even know I had. lol
Iāll get it done eventually. But yeah messing around with L5 is like another hobby.
For all the criticisms and issues we have, at least we canāt complain about the claim that it will get better with time. I think it is getting better. Instead of getting en-crapified with time like mainstream devices. Surprisingly I havenāt seen any of the lag or stutters mentioned above by Marts.
There was one thing I forgot to mention above. I tried turning off āautomatic lockingā so I wouldnāt need to unlock constantly when the screen on the dock/phone blanks (I think it means it only locks when I tell it to lock or by pushing the power button?), but the locking behavior remained totally the same. Under Settings->Privacy->Screen Lock. It seems like thatās just broken.
Also one of the more annoying convergence issues for me is the total lack of any ātask managerā or ālaunch barā or whatever we want to call where a desktop OS shows the applications running so you can switch windows. If you snap a window to the left and right, as soon as you get a third one itās a minor annoyance using the mobile-style switcher. But, at least it does work.
I need to go look for the official place to report issues, like that screen lock thing.
I really love this device. Sometimes I strongly dislike it. It is fun and interesting and I get to tinker. But, the rub is that it is constant effort. The thing needs lots of attention and I just want it to work sometimes so I can get on with my life. It is very much like woodworking or some other involved hobby.
