neoart
1
Hello everybody,
Just one month I have my first Librum and it’s is really really great.
Just one question, because I need to check the coreboot and all the post about the subject is a little old, I want to be sure.
How check definitely: coreboot and seabios are good and up to date ?
And the intel management technologie has been fully neutralist ?
Thanks a lot.
mladen
2
Run sudo dmidecode | grep Version to check your version, the latest is v4.11-Purism-1
Instructions here under Verifying the Intel ME is neutralized paragraph: Coreboot Firmware on Purism Librem Devices – Purism
@mladen I think there’s a missing link in your post
neoart
4
Thank’s !
it’s ok for coreboot and the bios but; yes something probably missing:
where I can find the paragraph on intel ME ? The dmidecode, give the info ? because I have nothing on my result :
Version: 4.11-Purism-1 Version: 1.0 Version: 1.0 Version: Not Specified Version: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz
Thanks a lot mladen and taylor
