Crappy bird touch(flappybird'ish) for Librem 5 and Whatever
Who wants to play a worse-than-Atari version of flappy bird on your Librem with green bar pipes, a blue background, and a red dot for bird. Bang away at the touch screen to 'flap", edit the python to fix speed or pipe sizes.
import pygame
import sys
import random
from enum import Enum
class GameState(Enum):
    MENU = 1
    PLAYING = 2
    GAME_OVER = 3
class FlappyBird:
    def __init__(self):
        pygame.init()
        # Screen dimensions
        self.WIDTH = 400
        self.HEIGHT = 600
        self.screen = pygame.display.set_mode((self.WIDTH, self.HEIGHT))
        pygame.display.set_caption("Flappy Bird")
        # Colors
        self.WHITE = (255, 255, 255)
        self.BLACK = (0, 0, 0)
        self.GREEN = (0, 200, 0)
        self.RED = (255, 0, 0)
        self.BLUE = (100, 149, 237)
        # Clock for FPS
        self.clock = pygame.time.Clock()
        self.fps = 60
        # Game state
        self.state = GameState.MENU
        self.score = 0
        self.high_score = 0
        # Initialize game objects
        self.init_game()
    def init_game(self):
        """Initialize or reset game objects"""
        # Bird properties
        self.bird_x = self.WIDTH // 4
        self.bird_y = self.HEIGHT // 2
        self.bird_width = 30
        self.bird_height = 30
        self.bird_velocity = 0
        self.gravity = 0.6
        self.flap_strength = -12
        # Pipes
        self.pipe_width = 50
        self.pipe_gap = 120
        self.pipe_velocity = -5
        self.pipes = []
        self.spawn_pipe()
        self.score = 0
    def spawn_pipe(self):
        """Create a new pipe pair"""
        min_height = 50
        max_height = self.HEIGHT - self.pipe_gap - 50
        pipe_height = random.randint(min_height, max_height)
        self.pipes.append({
            'x': self.WIDTH,
            'top_height': pipe_height,
            'bottom_y': pipe_height + self.pipe_gap,
            'scored': False
    def handle_input(self):
        """Handle user input"""
        for event in pygame.event.get():
            if event.type == pygame.QUIT:
                return False
            # Detect any touch/click to flap
            if event.type == pygame.MOUSEBUTTONDOWN or event.type == pygame.KEYDOWN:
                if self.state == GameState.MENU:
                    self.state = GameState.PLAYING
                elif self.state == GameState.PLAYING:
                    self.bird_velocity = self.flap_strength
                elif self.state == GameState.GAME_OVER:
                    self.init_game()
        return True
    def update(self):
        """Update game logic"""
        if self.state != GameState.PLAYING:
            return
        # Apply gravity
        self.bird_velocity += self.gravity
        self.bird_y += self.bird_velocity
        # Update pipes
        for pipe in self.pipes:
            pipe['x'] += self.pipe_velocity
            # Check if bird passed the pipe
            if not pipe['scored'] and pipe['x'] + self.pipe_width < self.bird_x:
                pipe['scored'] = True
                self.score += 1
        # Remove pipes that are off-screen
        self.pipes = [p for p in self.pipes if p['x'] + self.pipe_width > 0]
        # Spawn new pipe when needed
        if len(self.pipes) == 0 or self.pipes[-1]['x'] < self.WIDTH - 200:
            self.spawn_pipe()
        # Check collisions
        if self.check_collision():
            self.state = GameState.GAME_OVER
            if self.score > self.high_score:
                self.high_score = self.score
    def check_collision(self):
        """Check if bird collided with pipes or boundaries"""
        # Ground and ceiling collision
        if self.bird_y + self.bird_height > self.HEIGHT or self.bird_y < 0:
            return True
        # Pipe collision
        bird_rect = pygame.Rect(self.bird_x, self.bird_y, self.bird_width, self.bird_height)
            # Top pipe
            top_pipe_rect = pygame.Rect(pipe['x'], 0, self.pipe_width, pipe['top_height'])
            if bird_rect.colliderect(top_pipe_rect):
                return True
            # Bottom pipe
            bottom_pipe_rect = pygame.Rect(pipe['x'], pipe['bottom_y'], self.pipe_width, self.HEIGHT - pipe['bottom_y'])
            if bird_rect.colliderect(bottom_pipe_rect):
                return True
        return False
    def draw(self):
        """Draw game elements"""
        self.screen.fill(self.BLUE)
        # Draw pipes
            # Top pipe
            pygame.draw.rect(self.screen, self.GREEN, (pipe['x'], 0, self.pipe_width, pipe['top_height']))
            # Bottom pipe
            pygame.draw.rect(self.screen, self.GREEN, (pipe['x'], pipe['bottom_y'], self.pipe_width, self.HEIGHT - pipe['bottom_y']))
        # Draw bird
        pygame.draw.rect(self.screen, self.RED, (self.bird_x, self.bird_y, self.bird_width, self.bird_height))
        # Draw UI
        font = pygame.font.Font(None, 36)
        score_text = font.render(f"Score: {self.score}", True, self.WHITE)
        self.screen.blit(score_text, (10, 10))
        # Draw game state text
            menu_font = pygame.font.Font(None, 48)
            title = menu_font.render("Flappy Bird", True, self.WHITE)
            instruction = font.render("Tap/Click to Start", True, self.WHITE)
            self.screen.blit(title, (self.WIDTH // 2 - title.get_width() // 2, self.HEIGHT // 3))
            self.screen.blit(instruction, (self.WIDTH // 2 - instruction.get_width() // 2, self.HEIGHT // 2))
            gameover_font = pygame.font.Font(None, 48)
            gameover_text = gameover_font.render("Game Over", True, self.WHITE)
            high_score_text = font.render(f"High Score: {self.high_score}", True, self.WHITE)
            restart_text = font.render("Tap/Click to Restart", True, self.WHITE)
            self.screen.blit(gameover_text, (self.WIDTH // 2 - gameover_text.get_width() // 2, self.HEIGHT // 3))
            self.screen.blit(high_score_text, (self.WIDTH // 2 - high_score_text.get_width() // 2, self.HEIGHT // 2 - 40))
            self.screen.blit(restart_text, (self.WIDTH // 2 - restart_text.get_width() // 2, self.HEIGHT // 2 + 40))
        pygame.display.flip()
    def run(self):
        """Main game loop"""
        running = True
        while running:
            running = self.handle_input()
            self.update()
            self.draw()
            self.clock.tick(self.fps)
        pygame.quit()
        sys.exit()
if __name__ == "__main__":
    game = FlappyBird()
    game.run()
I made a .deb for myself if that is desired
here is something slightly better looking with cute clouds and the bird has an eye but also worse somehow
#!/usr/bin/env python3
import pygame
import sys
import math
import random
# Initialize Pygame
pygame.init()
pygame.mixer.init()
# Screen dimensions
SCREEN_WIDTH = 400
SCREEN_HEIGHT = 600
# Colors
SKY_BLUE = (135, 206, 235)
GRASS_GREEN = (34, 139, 34)
PIPE_GREEN = (34, 177, 76)
PIPE_DARK = (0, 100, 0)
RED = (255, 0, 0)
BLACK = (0, 0, 0)
# Game physics
GRAVITY = 1
FLAP_STRENGTH = -12
PIPE_VELOCITY = -30
PIPE_WIDTH = 52
PIPE_GAP = 120
    MENU = 1
    PLAYING = 2
    GAME_OVER = 3
class Bird:
    def __init__(self):
        self.x = 50
        self.y = SCREEN_HEIGHT // 2
        self.velocity = 0
        self.radius = 12
    def flap(self):
        self.velocity = FLAP_STRENGTH
    def update(self):
        self.velocity += GRAVITY
        self.y += self.velocity
    def draw(self, surface):
        # Draw bird as a circle with a simple eye
        pygame.draw.circle(surface, RED, (int(self.x), int(self.y)), self.radius)
        # Eye
        pygame.draw.circle(surface, WHITE, (int(self.x) + 5, int(self.y) - 3), 4)
        pygame.draw.circle(surface, BLACK, (int(self.x) + 6, int(self.y) - 3), 2)
class Pipe:
    def __init__(self, x):
        self.x = x
        self.gap_y = random.randint(100, SCREEN_HEIGHT - PIPE_GAP - 100)
        self.width = PIPE_WIDTH
        self.gap = PIPE_GAP
        self.passed = False
    def update(self):
        self.x += PIPE_VELOCITY
        # Top pipe
        top_height = self.gap_y
        pygame.draw.rect(surface, PIPE_GREEN, (self.x, 0, self.width, top_height))
        pygame.draw.rect(surface, PIPE_DARK, (self.x, 0, self.width, top_height - 4))
        # Bottom pipe
        bottom_y = self.gap_y + self.gap
        bottom_height = SCREEN_HEIGHT - bottom_y
        pygame.draw.rect(surface, PIPE_GREEN, (self.x, bottom_y, self.width, bottom_height))
        pygame.draw.rect(surface, PIPE_DARK, (self.x, bottom_y, self.width, bottom_height - 4))
def draw_clouds(surface, offset):
    """Draw simple clouds with parallax effect"""
    cloud_color = (240, 240, 240)
    clouds = [
        (50, 80), (150, 120), (250, 60), (350, 100)
    for cx, cy in clouds:
        x = (cx + offset) % (SCREEN_WIDTH + 100) - 50
        # Cloud: three circles
        pygame.draw.circle(surface, cloud_color, (int(x), cy), 20)
        pygame.draw.circle(surface, cloud_color, (int(x) + 20, cy), 25)
        pygame.draw.circle(surface, cloud_color, (int(x) + 40, cy), 20)
def draw_background(surface, cloud_offset):
    """Draw sky and clouds"""
    surface.fill(SKY_BLUE)
    draw_clouds(surface, cloud_offset)
    # Simple grass at bottom
    pygame.draw.rect(surface, GRASS_GREEN, (0, SCREEN_HEIGHT - 20, SCREEN_WIDTH, 20))
def load_sounds():
    """Load sound effects from package data"""
    sounds = {}
    try:
        # Try to load from package installation directory
        sounds['flap'] = pygame.mixer.Sound('/usr/share/flappybird/whoosh.ogg')
        sounds['bing'] = pygame.mixer.Sound('/usr/share/flappybird/fwooosh.ogg')
    except:
        print("Warning: Sound files not found. Game will run without sound.")
        # Create silent placeholder sounds so the game doesn't crash
        silent = pygame.mixer.Sound(buffer=bytes([0] * 1000))
        sounds['flap'] = silent
        sounds['bing'] = silent
    return sounds
def main():
    screen = pygame.display.set_mode((SCREEN_WIDTH, SCREEN_HEIGHT))
    pygame.display.set_caption("Flappy Bird Clone")
    small_font = pygame.font.Font(None, 24)
    # Load sounds
    sounds = load_sounds()
    # Game variables
    bird = Bird()
    pipes = []
    score = 0
    cloud_offset = 0
    pipe_spawn_counter = 0
    running = True
    while running:
        clock.tick(60)
        # Event handling
                running = False
                if state == GameState.MENU:
                    bird = Bird()
                    pipes = []
                    score = 0
                elif state == GameState.PLAYING:
                    bird.flap()
                    sounds['flap'].play()
                elif state == GameState.GAME_OVER:
        # Update game logic
            bird.update()
            cloud_offset -= 0.5  # Slow cloud parallax
            # Spawn pipes
            pipe_spawn_counter += 1
            if pipe_spawn_counter > 90:  # Spawn every ~1.5 seconds at 60 FPS
                pipes.append(Pipe(SCREEN_WIDTH))
            # Update pipes
            for pipe in pipes:
                pipe.update()
                if not pipe.passed and pipe.x + pipe.width < bird.x:
                    pipe.passed = True
                    score += 1
                    sounds['bing'].play()
            # Remove off-screen pipes
            pipes = [p for p in pipes if p.x > -p.width]
            # Collision detection
            if bird.y - bird.radius < 0 or bird.y + bird.radius > SCREEN_HEIGHT - 20:
            for pipe in pipes:
                # Check if bird collides with pipe
                if (bird.x + bird.radius > pipe.x and
                    bird.x - bird.radius < pipe.x + pipe.width):
                    if (bird.y - bird.radius < pipe.gap_y or
                        bird.y + bird.radius > pipe.gap_y + pipe.gap):
        # Draw everything
        draw_background(screen, cloud_offset)
            title = font.render("Flappy Bird", True, BLACK)
            start = small_font.render("Click or Press Any Key to Start", True, BLACK)
            screen.blit(title, (SCREEN_WIDTH // 2 - title.get_width() // 2, 150))
            screen.blit(start, (SCREEN_WIDTH // 2 - start.get_width() // 2, 300))
            bird.draw(screen)
            bird.draw(screen)
            for pipe in pipes:
                pipe.draw(screen)
            score_text = font.render(str(score), True, BLACK)
            bird.draw(screen)
            for pipe in pipes:
                pipe.draw(screen)
            game_over_text = font.render("Game Over", True, BLACK)
            final_score = small_font.render(f"Score: {score}", True, BLACK)
            restart = small_font.render("Click or Press Any Key to Restart", True, BLACK)
            screen.blit(game_over_text, (SCREEN_WIDTH // 2 - game_over_text.get_width() // 2, 150))
            screen.blit(final_score, (SCREEN_WIDTH // 2 - final_score.get_width() // 2, 250))
            screen.blit(restart, (SCREEN_WIDTH // 2 - restart.get_width() // 2, 320))
    pygame.quit()
    sys.exit()
    main()
I know that the AI could make this instantly, so for my own curiosity is this AI generated or did you sit and write this?
mixed, I 100% dont know which libs to use and am terrible at debugging if I mess up. But in my experience AI rarely works/compiles at all without a human hand. Before this I had to scour the internet for code examples to hack so similar situation except I can customize it better.
So you’re probably using bad AI. I am working in a software job where I am likely to get pushed out by younger guys who just AI everything. I tried at home in containment (separate hardware, clean install) the AIs they are using and the AI was able to build a working version of a desktop computer game I created as a hobby over about 10 years and any time the game had a bug, I typed into the AI without reading the code “it has a bug fix it” and after a couple of prompts the result is a working instance of essentially the entire game made by the AI.
There may be many ethical problems with AI but the limits to its capability are ever-changing as long as people keep using it and iterating on it. I wouldn’t assume that it doesn’t work simply because that fits one’s life narrative or desire.
If it makes you feel better, I and likely most users her have contributed to the Q&A over something that landed in forums, stackoverflow, reddit, even usenet. Our work is farmed and harvested to train these so called AI models. Why not take advantage while we can still get free access during the DARE phase where the dealer is giving out the free dope. It is our work they are packaging and selling off. There are those who say using ‘ai’ code and assets is cheating, I reply that I never signed up for a race, you can run I will ride in a car to get my groceries if I have access. I suspect the quality is crap because I am running the helper LLM on my own video card.
I made a console version back in the day :laughing:
there is this, it runs in the browser, it is also unplayable IMO.
git clone https://github.com/noanonoa/flappy-bird.git
`cat > ~/.local/share/applications/flappy-bird.desktop << ‘EOF’
[Desktop Entry]
Version=1.0
Type=Application
Name=Flappy Bird
Comment=Flappy Bird clone
Exec=sh -c “cd ~/flappy-bird && python3 -m http.server 8000 & sleep 2 &&
epiphany http://localhost:8000”
Icon=XXX
Terminal=false
Categories=Game;ActionGame;
EOF`
chmod +x ~/.local/share/applications/flappy-bird.desktop
runs in browser, cant even make the first pipe gap…
the real trick to flappybird was making it playable balancing the speed, flap-jump and gravity.
