looks like it is still broken for rc3 ![]()
I was forced to move Airtel Sim to FLX1 so I can use posh osk stevia there to enter UPI id for payments.
Since *99# is already broken on Vi, I could switch to squeekboard and install phosh 0.58. I also installed mesa from octarine.
So the steps (unsupported - try at your own risk - you need to fix dependency problems manually).
- apt dist-upgrade to dawn (this would fail due to unl0kr conflicting osk-sdl, so apt remove osk-sdl and complete dist-upgrade)
- add octarine repo and install phosh phoc and phosh-plugins from octarine.
Another thing I noticed in both crimson and dawn is - with 1 minute delay for automatic suspend, the phone hangs when it is close to 100% battery. So now I set automatic suspend delay to 2 minutes while using battery. To be safer, I disabled automatic suspend when charging.
Even fully disabling automatic suspend, it still hangs sometimes. I’m now turning off wifi kill switch to try if wifi is causing it. I have to figure out the root cause of the hang (I noticed it on crimson as well as on dawn). It happens on both 6.12 and 6.18 kernels.
I’ve also observed situation when my display do not wake up correctly. It can blink for a second and blacked again. Crimson backports, both 6.12 and 6.18 kernels.
I see similar on regular Crimson sometimes when turning on the display via power button. I think it’s usually when media was playing in Kasts or VLC.
Thanks for confirming, I was suspecting something else broke on my phone as I have been doing many re-installs and upgrades to dawn and phosh from octarine etc I reported it here Recent kernels break wake up from suspend - both 6.12 and 6.18 kernels do (#140) · Issues · PureOS / Tasking · GitLab
Media together with bluetooth headphones?
I notice it when leaving it unattended for a long time - like charging over night or even just leaving without charger connected. Nothing was running in the foreground. Once it hangs, sometimes you have to remove battery and reinsert to boot it again. Once booted I can see it has not run out of battery charge. I think it stopped after disabling automatic suspend or if I remember correctly I also had to turn off wifi kill switch. Last two days I did not see it repeating.
- Suspend is completely turned off - both in battery and when charging
- wifi kill switch is turned off
I will update here if I see it again.
Just now it crashed and restarted, this time while using Gajim from flatpak. This could be due to dawn/octarine too as it was different from earlier times (crash/restart vs hang/blank).
No, analog headphones only.
I’m continuing this here: Screen does not back come on with power button sometimes as I’m on plain Crimson, nothing added except flathub.
