Data usage /network traffic monitoring
Looking for a way to see how much internet data each application is using. Currently my Librem 15 running pureos is hemorrhaging data.
System manager and sort by network, if you want more detail use nethogs, just type
nethogs
Into there terminal
thanks for your reply. I could find System monitor (but not manager) and under the resources tab > network history, I am able to see total MB in and out.
Typing nethogs into terminal produced this error -
Could not find the database of available applications, run update-command-not-found as root to fix this
Running update-command-not-found produced the same error.
Advice on how to fix this would be appreciated.
Regards
There’s the git for it though it should be a preinstalled debian package
