A month ago I successfully scanned a doc with the Document Scanner PurOS software. I have an HP Envy 6000 series printer.
Yesterday I tried to scan and the Document Scanner message said ‘cannot connect to scanner’.
I have printed a test page with the HP Printer and it works fine.
Any ideas on what I can try?
Thanks a whole bunch
Hope this check-up checklist (few partial tips) helps:
$ sudo apt update
$ apt list hplip
(sudo apt install hplip
−− if not installed)
$ apt list sane-utils
$ scanimage -L
$ scanimage --help -d DEVICE''
$ apt list xsane xsane-common
$ xsane
−− please click on Scan
icon.
Hello Quarnero
Thanks for the response.
I will give it a try.
Really appreciate it.
Belerry
Hello again
Just wanted to share a quick update.
The scanner / printer / back up flash drive issues all appear to have stemmed from an automatic ‘update’ from Purism. I have been working with a Support rep at Purism Support and after running some ‘fixes’ everything now seems to be almost normal.
Really appreciate everyone’s help
Thanks
Belerry
Trying to scan with hp laserjet MFP M141w
Recognized with Document scan as hp laserjet MFP M141w (C984E7) (USB)
I followed the steps Quarnero posted.
Installed xsane
$ xsane
Error
X Failed to open device ‘escl:http://127.0.0.1:60000’ : Out of memory.
Failed to load module “canberra-gtk-module”
$ sudo apt install libcanberra-gtk-module
run xsane again.
same result.
Did you contact Purism support and worked with them for running some “fixes”?
