Does the Librem key use usb_storage module?
I am running PureOS on a Librem mini with a Librem Key. Does anyone know if the Librem Key uses usb_storage kernel module? I would like to blacklist that module but I wanted to triple check here.
Thanks in advance!
Not sure, but you may find out more information in its firmware’s repository.
The comments made previously apply: make sure that you have a backup and make sure that you have a bootable USB flash drive. In case it all goes pear-shaped.
Assuming that you are using Pureboot, you should be able to bypass a failure to boot with integrity if you manage to break the Librem Key.
It seems not to use usb_storage! I was able to blacklist that module and reboot without any issue. Thanks so much all for weighing in!
