Error syncing lockdown repo after kernel upgrade on PureOS 11
Just upgraded to kernel 6.1.0-38-amd64 on PureOS 11. When I went to update the system afterwards using apt I got an error for the repository below. Anyone else reproducing this issue?
E: The repository 'https://releases.lockdown.systems/debian prod Release' no longer has a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
This is not a PureOS repository. You have added some external repository to your system and there’s some problem with it now (perhaps it was discontinued?), unrelated to the kernel upgrade.
Thanks, does appear now that the timing was coincidental.
The repo most likely belongs to Micah Lee’s Cyd app. which I have installed.
Another apt update operation completed today without errors.
