Error using package updater
Hi, I receive the attached error when trying to run package updater.
Librem 14. PureOS 10 (Byzantium).
Try: sudo apt --fix-broken install
Related:
Reading package lists… Done
Building dependency tree… Done
Correcting dependencies… failed.
grass : Depends: libwebkit2gtk-4.1-0 but it is not installable
grass-core : Breaks: grass (< 6.4.2-1~) but 4.30.0 is installed
grass-gui : Breaks: grass (< 6.4.2-1~) but 4.30.0 is installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
sudo apt remove <insert name of whatever package you installed that didn’t work>
You either have to go forward or backward. You can’t go forward unless you can resolve those unmet dependencies. So just going backward is the right approach i.e. get rid of the problem package. At least then you can use the system normally to apply updates and to install new packages that do work.
sudo dpkg --purge --force-depends grass grass-core grass-gui
this worked…thankyou so much!
Which particular command worked?
