FYI the kernel update has just arrived in the production repos that should take the battery counter from “very likely totally off” into “pretty accurate” territory
There will also be another update that should take it even further into “as accurate as it can get”, but no idea yet when that will happen.
cc : @amarok Hello, just a question, did you try tlp to know if the program improve battery life ? Thank you !
No, I didn’t.
@joao.azevedo - Do you think this would have any applicability to the L5 in its current state?
That is a question more to @dos or @angus.ainslie
I don’t expect tlp to be able to do anything sensible on a phone.
@amarok FYI a kernel update with the battery gauge fix that actually makes it usable on Evergreen (For Real This Time™) and more accurate on all batches has just entered amber-phone-staging and should migrate to amber-phone in a week
Lol! Great! Thanks, dos.
Oh well I am testing that right now ![]()
