Not sure which forum “Pureboot / Coreboot” questions should go into.
I have a Librem Mini v2 which came with Pureboot. It can’t seem to boot hardly anything.
- PureOS 9.0 gnome live 20200806 amd64: freezes at “Starting new kernel”.
- Debian installer gives weird coloured lines/rows just at the top of the monitor. I think it’s showing the installer menu but it’s unreadably tiny / corrupt graphics.
- NixOS Failed to find file /boot/grub/()/nix/store//…
The only thing I can seem to boot into is this developer release of PureOS that someone linked me to:
https://downloads.puri.sm/byzantium/gnome/2020-11-20/pureos-10~devel-gnome-live_20201120-amd64.hybrid.iso
Using the live installer, I tried to replace PureBoot with CoreBoot using coreboot_util.sh from firmware / utility · GitLab
This failed at:
coreboot flashing in progress. Do NOT interrupt this process.
Initializing internal Flash Programmer
Error flashing coreboot -- see timestampped flashrom log in current directory for more info
The flashrom-.log has:
flashrom v1.2-116-gc64486b on Linux 5.9.0-1-amd64 (x86_64)
flashrom was built with libpci 3.7.0, GCC 10.2.1 20210110, little endian
Command line (7 args): ./tools/flashrom/flashrom -p internal:ich_spi_mode=hwseq -w ./firmware/coreboot-librem_mini_v2-4.13-Purism-1.rom -V -o ./flashrom-20210420-045227.log
Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
Initializing internal programmer
Found candidate at: 00000500-00000528
Found coreboot table at 0x00000500.
Error accessing high tables, 0x100000 bytes at 0x0000000099b82000
/dev/mem mmap failed: Operation not permitted
Failed getting access to coreboot high tables.
Using Internal DMI decoder.
Error accessing DMI Table, 0x1000 bytes at 0x0000000099b5d000
