Fast Scroll with Scroll Wheel Click?
Hello,
I mostly use my L14 with a wireless mouse and keyboard. The mouse has a scroll wheel that I’m accustomed (on Windows) to being able to click, at which point the mouse arrow becomes a 4-sided arrow and I can do a fast scroll up or down depending on which way I move the mouse.
I’ve noticed that this feature does not work in PureOS and that if I want to fast scroll I have to move the mouse to the scroll bar on the side of the screen and click and drag up or down.
Is there a way to enable the click on the scroll wheel for a fast scroll function?
Thanks!
I second this notion. I use a Logitech M185, and I also would like my fast scroll with wheel click feature back. Any help on how to re-enable this would be greatly appreciated.
Does nobody know how to fix this issue?
You might check out the Solaar utility.
I just used it to get mouse wheel scrolling working on Librem 5
