File manager problems - L5
Thanks for any help that may come forward here.
When I open “Files” on my L5 it takes me to the screen with 'Desktop, Documents, Downloads, Music" etc. I am trying to get to my sd card and other drives as required via, I think, “Other Locations” . When I launch “Files” I do get a brief look at the window I want, just a glimpse, but it moves past it to the window above.
I have been access this before, but now its not playing the game.
Any help gratefully accepted.
For me it works to tap the little symbol at the top-left corner of the screen, then a menu is shown with such things, including “other location”, and from there “Computer”, which takes me to the root of the filesystem.
You can toggle Nautilus’ sidebar by tapping the icon on the top left of the interface:
Thanks. Yes, I can get that far (now!), but nothing opens. If I tap it will highlight the folder, like say "Documents " but I can’t open anything in there. For example I can’t open a text document by going in that way, but I can open it via "'text editor " tge app.
The phone hasn’t been turned on for a week or more. Strange beast.
There is also the issue that you cannot tap a file to open it, I got around that by bringing up the keyboard (small button at bottom-right corner) and then pressing the Enter key on the keyboard.
Thanks. I just found that that method does indeed work. But I also found that documents would open ok if I changed the view of the initial window with docs, music etc in it. It opens by default with a list. If I change it so that I have folders going across the page, rather than the list that is horizontal down the page, then things like text files open with a tap.
I’ll have to attack this later. Things like employment call. A linux task awaits tomorrow. Love these challenges (when I’m in the mood…and not say, in a hurry)!
