Hello All,
I installed Firefox ESR - and it is appearing in the applications menu, and it will open regarding it’s own functional settings. However, it will not open any website. There is no error message, just a blank white page for any site. I attempted to uninstall the program through the terminal - but it is saying that firefox is not recognized (has not been installed). And it doesn’t appear in the installed list. Any advice would be appreciated. Thanks
How did you install it?
HI @dcz
sudo apt install firefox-esr
Hi @dcz
After doing an OS update - it appears the issue has been resolved. Thank you for taking the time to respond.
For future reference, when dealing with software you have to use the same name you used to install it. Firefox not being recognized is because you installed firefox-esr, not firefox.
