Firmware and USB Issues
I am using a Librem 13v2 (updated software/coreboot 4.7), and am running into the below firmware issues. Any advice on how to solve them would be appreciated.
$ sudo dmesg | grep firmware
[ 0.030427] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 1.602017] i915 0000:00:02.0: firmware: failed to load i915/skl_dmc_ver1_26.bin (-2)
[ 1.602023] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[ 1.602028] i915 0000:00:02.0: Direct firmware load for i915/skl_dmc_ver1_26.bin failed with error -2
[ 1.602030] i915 0000:00:02.0: Failed to load DMC firmware i915/skl_dmc_ver1_26.bin. Disabling runtime power management.
[ 1.602031] i915 0000:00:02.0: DMC firmware homepage: https://01.org/linuxgraphics/downloads/firmware
[ 2.861949] psmouse serio1: elantech: assuming hardware version 4 (with firmware version 0x361f00)
[ 14.922353] platform regulatory.0: firmware: failed to load regulatory.db (-2)
[ 14.922357] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 14.984525] usb 1-3: firmware: failed to load ar3k/AthrBT_0x11020100.dfu (-2)
[ 14.984530] usb 1-3: Direct firmware load for ar3k/AthrBT_0x11020100.dfu failed with error -2
Yes, I get many of those messages as well.
[ 2.533984] psmouse serio1: elantech: assuming hardware version 4 (with firmware version 0x361f00)
[ 46.829579] platform regulatory.0: firmware: failed to load regulatory.db (-2)
[ 46.829583] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[ 46.829586] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 46.958798] usb 1-3: firmware: failed to load ar3k/AthrBT_0x11020100.dfu (-2)
[ 46.958803] usb 1-3: Direct firmware load for ar3k/AthrBT_0x11020100.dfu failed with error -2
[ 4150.832719] usb 1-3: firmware: failed to load ar3k/AthrBT_0x11020100.dfu (-2)
[ 4150.832739] usb 1-3: Direct firmware load for ar3k/AthrBT_0x11020100.dfu failed with error -2
I get these error messages as well, any reason why?
Because there is no firmware to load. You can safely ignore these warnings, as the hardware work normally without firmware.
For my USB on the left side of the laptop, using an Libre 13v2 w/Coreboot 4.8.1 now, it is still unresponsive. It just stopped working one day (even before the Coreboot update), and I can no longer use the port for anything.
You need to contact us then, as it might be a hardware issue.
