Firmware: coreboot 4.18-Purism-1, PureBoot Release 24
  • Rebased on upstream coreboot 4.18 release/tag
  • Fixed left-side USB-C port on Librem 14, super speed now works in both plug orientations
  • Updated Intel microcode to latest releases:
    • CNL: F0 → F4 (CPUIDs 806EC, A0660)
PureBoot Release 24
  • PureBoot Basic: Add USB automatic boot configuration setting.
    • When enabled, bootable USB devices are booted by default instead of the installed operating system.
  • PureBoot Basic: Boot first installed menu entry by default.
    • Default boot options no longer have to be configured manually, and no reconfiguration is needed if the OS kernel is updated.
    • This can be disabled in configuration to configure a custom boot option instead.
  • Ignore device specifications in GRUB menu entries - fixes PureOS installer’s GRUB/EFI boot options.
  • Rebased on HEADS upstream master branch (139ecb8)
  • Updated all devices (except L1UM) to coreboot 4.18-Purism-1 (tag)
As always, you can update using coreboot_util.sh:
https://source.puri.sm/firmware/utility/-/blob/master/coreboot_util.sh
Thanks.
Also i will happy if you get perform an smart hack to run Coreboot without Microcode compat Pure OS, i just not want not need intel ridiculous blobs sign in on my L14.
I hope you also do not run any proprietary javascript, otherwise it could probably read all your passwords from RAM…
The sources are available to you so that you can remove the Intel microcode yourself. Right?
Whether that gives you
a) a computer that won’t boot at all, or
b) a computer that has a security regression (missing out on important security fixes), or
c) a computer that is completely satisfactory
I don’t know.
If i remove the microcode from coreboot then the system crash after seconds of boooting, because ME partitions need a ridiculous microcode sign to keep machine ON. So we need to wash more blobs from ME to prevent microcode sign. IMHO Purism need stop using intel.
