flash-kernel triggers looping
I got a looping with my last update upgrade on L5:
dpkg: error processing package flash-kernel (--configure):
 triggers looping, abandoned
Errors were encountered while processing:
 linux-image-6.18.0.1-librem5
 linux-image-librem5
 libvlc-bin:arm64
 flash-kernel
E: Sub-process /usr/bin/dpkg returned an error code (1)
I solved telling dpkg to configure all packages that are only half-installed or unpacked:
sudo dpkg --configure -a
I have not yet tried on my L14.
Has anyone else got a similar issue?
Yes. This should be harmless and self-correcting, but an update to prevent it from happening in the first place is about to enter the repositories. It’s Librem 5 specific.
