As I read in FAQ that librem phone would probabely run Android, I understood that a phone that was designed for Android (Samsung S series) would probabely run PureOS…
I have a S7-2018 iddleling around there
Question: is there somewhere a flashable ROM image of PureOS ? Or a source GITHUB tree for that ?
I assume purism won’t invest efforts to port pureos to other devices, however they work open source so hopefully other people like postmarketos use it so that the user base can be as large as possible for linux on phones.
Once you had a look into postmarketos you will see that calls do not yet work and that most of the devices don’t support a lot of stuff. Even the Galaxy S3 which was partially mainlined sucked once I installed postmarketos with plasma mobile due to lacking graphic drivers support.
