No other errors are displayed; I can successfully decrypt via luks. The progress bar for loading proceeds very slowly; takes about 2 minutes, and then bails to busy box.
Attempting to boot from recovery has the following errors thrown:
Warning: failed to connect to lvmetad. Falling back to device scanning.
@rjrjr It’s unrelated to the core problem you’re facing, but I had the same lvmetad error message as you, and solved it by following these two simple steps to turn lvmetad off (it’s unnecessary from what I read):
Oh darn, I saw another post about that lvmetad that recommended a reinstall. Ah well, good to know I can bail to another terminal and try to upgrade. Will I have internet connectivity at that point in the boot cycle?
