I may be missing something here, and I’m not an ace on debian. Typing
sudo su
does not give me an administrator shell. I get a message telling me that my account has expired and to contact my administrator. Am I usung the correct command?
sudo su
You can use this command:
sudo -i
or this one
sudo bash
sudo -s
Now I got curious about the difference between -i and -s.
man sudo says:
-i, --login
Run the shell specified by the target user's password database entry as a login shell.
-s, --shell
Run the shell specified by the SHELL environment variable if it is set or the shell specified by the invoking user's password database entry.
Thanks. I suspected a user error. I’ll check out later
After evaluating your need to be running commands directly as the root user rather than using sudo, the following commands may be used to adjust the expiration date of the root user and therefore enable direct shell access:
$ man chage
NAME
chage - change user password expiry information
-E, --expiredate EXPIRE_DATE
Set the date or number of days since January 1, 1970 on which the
user's account will no longer be accessible. The date may also be
expressed in the format YYYY-MM-DD (or the format more commonly
used in your area). A user whose account is locked must contact the
system administrator before being able to use the system again.
For example the following can be used to set an account to expire
in 180 days:
chage -E $(date -d +180days +%Y-%m-%d)
Passing the number -1 as the EXPIRE_DATE will remove an account
expiration date.
-l, --list
Show account aging information.
Examples:
sudo chage -l rootsudo chage -E never rootsudo chage -E 2025-12-31 root
