Hardware mods for Librem 15 v3
What modifications is possible to make by your own with the Purism Librem 15 v3 motherboard? For example to solder DisplayPort or another Mini PCI-E?
I can’t really say much about the motherboard itself, but there are a couple of points that are set in stone:
  • the modem is going to be on an M.2 connector, and have USB access
  • the WiFi/BT card will also be connected with M.2 and have SDIO bus access
  • there will be no PCI-E used for anything
