Helium AppImage fails to launch on PureOS Crimson due to squashfs xz zlib error
Downloaded helium-0.13.1.1-x86_64 from https://helium.computer/ and tried to launch.
Fails with the following error in the terminal
$ ./helium-0.13.1.1-x86_64.AppImage
Squashfs image uses (null) compression, this version supports only xz, zlib.
ERROR: appimage_shall_not_be_integrated : sqfs_open_image error: /home/user/Downloads/helium-0.13.1.1-x86_64.AppImage
AppImageLauncher error: appimage_shall_not_be_integrated() failed (returned -1)
Probably another case of glibc version mismatch due to outdated Debian Bullseye 11 glibc libraries
Here are the most reliable ways to check your glibc version on PureOS 11 Crimson:
Method 1: Using ldd (quickest)
ldd --version
This outputs the version right at the top, e.g., ldd (Debian GLIBC 2.36-9+deb12u7) 2.36
Method 2: Query the libc binary directly
/lib/x86_64-linux-gnu/libc.so.6 --version
Or just run it without flags:
This prints the version along with copyright info.
Method 3: Using getconf
getconf GNU_LIBC_VERSION
Returns something like glibc 2.36
Method 4: Check via package manager
dpkg -l libc6
Or for more detail:
dpkg -s libc6 | grep Version
PureOS 11 Crimson is based on Debian 12 (Bookworm), so you should expect glibc version 2.36 unless you’ve done custom upgrades.
I assumed you are running it on PC. In case you’re doing this on Librem 5, the ARM build is here: Releases · imputnet/helium-linux · GitHub not on website or main repo.
The appimage worked for me on L5 with scaling down on in phosh mobile settings.
I did some more troubleshooting with other AppImages and determined that many of these errors were not actually glibc issues, they were bugs with AppImage Launcher v2.0. They have been resolved with the AppImage Launcher v3.x beta.
If you have an AppImage application that you want to inspect to see what GLIBC libraries in use, you can use this command:
chmod +x Foo.AppImage
./Foo.AppImage --appimage-extract >/dev/null
find squashfs-root -type f -exec file {} + | grep -i 'ELF' | cut -d: -f1 \
  | xargs objdump -T 2>/dev/null | grep -o 'GLIBC_[0-9.]*' | sort -uV | tail -3
