I mixed up my lib 13’s Power Adapter with another Power Adapter for usb hub. I think this is the right one:
FIYPOWER SWICHING ADAPTER
MODEL: PS65B120Y5000S
INPUT: 100-240-, 50/60HZ,1.5A
OUTPUT:12.0VR----5000mA
This one I think one is for USB hub:
The other Power Adapter is a:
OUTPUT:12.0V----5.0A 60.0W
Thanks for being able to post!
What you’ve posted are two adapters with the exact same output. Either one should work fine.
Even the model numbers are the same.
The botton lines are defferent, right?
5000 mA is the same as 5.0A (1000 mA or milliamps or milliamperes equals 1 A or amp or ampere).
Thanks for the help, now to get it charged up!
The Librem13 (as well as all other Purism laptops) need 19V DC voltage. 500mA current is way too low, at least you need 45W which at 19V is about 2.5A.
Cheers
nicole
Hey nicole, thank you a big bunch! I’m so glad you read my post, I had given up on finding the right adapter to charge up my laptop. I really was getting ready to order a new adapter, then I read your email - problem solved!
Thank you ever so much, you saved me bucks!! Thanks you so much!
Very welcome, glad I could help
Cheers
nicole
