Help with running PureOs in a VM (piix4_smbus error)
Dear community,
trying to install & run PureOS in a VMWare Workstation 12.5 VM, at boot I get an error printed:
piix4_smbus 0000:00:007.3: Host SMBus controller not enabled!
The resulting virtual machine is practically unusable - it does not respond to any inputs.
The above error is familiar (to at least Ubuntu and derivatives) but none of the workarounds i found (and configured) solves this (see below).
Do you have any ideas what to do or where to look next?
Many thanks, regards,
Willem
Workarounds (all are active):
  • put a line `` cpuid.1.eax = “0000:0000:0000:0001:0000:0110:1010:0101” ‘’ in the .vmx file (VMWare config)
  • blacklisting in the /etc/modprobe.d/blacklist.conf and /etc/modprobe.d/50-blacklist.conf (they are identical):
    blacklist i2c-piix4
    blacklist i2c_piix4
    blacklist intel_powerclamp
The above usually restores performance of Ubuntu etc. VMs, but PureOS doesn’t give in…
