fossman
                    December 30, 2024, 12:02pm
                  1
              Is it possible to hold and drag UI elements is apps without connecting a mouse?
I’m trying to collapse the annoying side bar/pane in Signal.
Would appreciate any tips. Thanks.
P.S. Tried Flare already - surprisingly it’s performance is worse than the bloated Signal electron app although UI is perfect.
                tracy
                    December 30, 2024,  1:59pm
                  2
              I remember old Apple][ games where you could old the arrow keys down with shift and the pointer would move right, left, up, and down.  Those asteroids and space invaders would always win however.
                fossman
                    December 31, 2024, 12:23am
                  4
              I was initially, but now on postmarketOS until Crimson comes out…
              I cannot provide Linux technical support outside of PureOS or Qubes OS, so explain your issue(s) in either the postmarketOS Matrix or IRC chatrooms:
