Hot Keys - change to additional function
Wondering on my Librem 14 if there is a way that when I just press “F5” and not “Fn” + “F5” to have the screen brightness reduce and the same for the other F keys. So pressing “F10” by itself would mute the computer, pressing F11 by itself would reduce the volume, etc. The reason is that I use these “additional” functions of the F keys much more than I use the F5 or F10 keys as they are programmed by default, so would ideally like to not have to hit the “Fn” key to trigger these “additional” functions. Then if I ever did need the original F5 function, I could hit “Fn” + “F5”. Thanks for any insight you can offer here.
I’m in the same boat. The key titled “Fn Tg” is I believe supposed to do this but has not been implemented yet in the EC as far as I know. Hopefully someday!
The source repo for the EC is here: LIbrem EC
Ah, ok. Bummer. Well yes, hopefully that will get implemented soon. Thanks for letting me know.
